Car died once while coasting last December. Started right up. Happened again two days ago. I thought it could be the IAC so I turned it up to 30. Yesterday it died while coasting again and it wouldn't start. Fuel pressure was 10 psi. Got it towed home, turned key and car started. Fuel pressure was back to 39 line on. It's a Reds pump, maybe 60k miles on it. If I replace the pump can I bend the float arm to get the vdo gauge to be more accurate? Gauge always goes past full, then by the time it reads 1/2 it is really closer to 1/4 tank of gas. Thanks guys
