Stock fuel line is 3/8, return line is 1/4, vent line is 5/16 - correct? Trying to hook up the fuel lines from the Racetronix Gen2 255LPH pump and carrier. The metal tubes on the new pump for both the return line and the vent line are both 5/16. The barbless quick connector for the return line is also 5/16. My sore hands attest to the fact that a 1/4 hose won’t go onto a 5/16 fitting. The return line from the front of the car is 1/4. Unit I’m replacing is stock, and the lines have not been switched. Advice? Thanks.
