Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
Yesterday I about had a fire and a load of $hit in my pants. Here is the story
I have a power logger, with the power logger I have a transducer. In order for me to be able to keep the transducer in line as well as connect my manual fuel gauge (setting pressure) I used this T. Last month's low pressure fuel issue was due to this T. If you tighten too much....the fuel gets obstructed to the transducer, as well as the manual gauge. It gives little to no pressure, where as....you truly do. So......while car is running hook up manual gauge. Turn on fuel pump...notice if any leaks. If leaks tighten the T. If no leaks leave it a little loose. Check manual gauge....does it read?? no....restart the tighten or loosen process until you see no fuel leak, as well as pressure. Simple right???? Lesson learned...no.
It appears enough vibration....or pressure, heat...etc, made the rail leak ALL over the intake and spray fuel onto the hood liner (thank goodness NOT the new old stock one).
Can you NOT use a T on the rail? I am pretty mechanical and used enough knock around sense....and just cannot get it to be safe and effective.
