SignUp Now!There are a lot of variables to come in to play other than rail ID. But, I have personally converted intakes with -8 rails for turbo motors that make 2100 hp on the engine dyno. That is usually with a single 160lb. injector per cylinder on c16 and two weldon 2025 pumps on 400+ cid motors. I have a feeling you could go even higher as long as you have enough fuel pump.
The -8 Edelbrock fuel rails have been high 6s in the 1/4.
yeah..I came across that on other forums alot of guys running fast or big HP numbers on those Edelbrock rails .I was also concerened if the fuel rails were to big in relation to injector sizing/pressure/volume . that the reg may not be able to bleed off enough volume/pressure at idle . the result being it would not be a true reading at or on the rail . am I thinking correctly on this , or would rail volume not play a critical role in this ?
Many thanks for your reply .
What goes into the rails minus what goes out of the injectors equals what the regulator has to bypass.
That makes sense . Great Info MeanMike ! thanksso.... a -6 return theoretically should be able to do the job on a high HP rating ?
Theoretically yes. But in reality comparing the same flow rate in a -8 or -10 to the same in a -6, the friction losses are pretty high because of the speed that fuel has to travel, length of the hose, bends in the hose ,etc. A fuel rail is 2' long at most with no bends, so friction losses are minimal.
For reference. The weldon 2040 regulator that most people use up to 2000hp has a return orifice of .281" and a -6 hose is roughly .325" ID.
