turbofabricator
- Mar 7, 2004
Here's the fuel pressure regulator fitting that I tinkered with this afternoon. It is 100% stainless and will replace the pressure regulator for those that want to run a bigger aftermarket external regulator. If you run dual Wlabro's in tank (and dont want the fuel spike when the second pump turns on), and have stock fuel rail, you can run this as a -6AN to a remote regulator and keep BOTH pumps running all the time, even on the street. IF the single -6AN isn't enough, just tap into the -4AN on the front of the rail and and run to your dual port pressure regulator. (see photo) I can make a fw of them if anyone is interested. There seems to be alot of questions about the flow capabilities of the stock style regulators. This may help some of you. PM me if you want one and I'll figure out what It's worth. It has a .276" ID compared to the stock regulator, which has a .174" ID in the return tube. The stock fuel rail port for the regulator is a .257" ID. So, you might need to run both fuel lines (see photo) if you have a BIG pump set-up. (The -4 hose on the fuel rail is not the right style fitting, I just slipped it together for a photo representation)
