Fuel system help/advice needed
ross87t
I've got my car apart right now and am needing some advice on what fuel system I will need. Right now, the car (86 t-type) has a single Red's in-tank pump, stock fuel lines, adj regulator, 60# injectors and Alkycontrol dual nozzle setup. I will list my power setup below. I am looking for advice on a fuel system that will be adequate for my combo with room to grow. I have also considered E85, but I'm not sure how I feel about having to run around on corn all of the time when the closest gas station that sells it is 10 miles from my house. Goal is deep 10's @ 125+mph. Any advice is appreciated. Thanks
stock 3.8 block .020 over
Eagle forged crank
Molnar forged rods
Wiseco forged pistons
Billet center and front main caps (still considering going with a girdle too)
Revolution X 210/215 roller cam kit w/ Morel lifters
Harland Sharp 1.60 roller rockers
Champion ported irons/Champion intake
Precision BB 62/62 turbo
PTE SLIC
3" THDP
3" Exhaust
The fuel system you have will get you into the mid 10's. I have been 10.48 @ 129 with the exact set up you have. The addition of a double pumper set up in the tank will get you into the 9's.
