Well I am almost finished with putting my long block together and I need to start thinking about what kind of fuel system to run. right now all i have is a 307 pump and some 42.5 inj. Here is what I was thinking of doing: keep the intank pump, weld another pickup tube in the sending unit plate and connect it to an external areomotive pump. Run both pumps to a Moroso Y block joining them into a -8 fuel line all the way to the pass side of the fuel rail. As for a return line i was going to come out of the regulator with a steel braided line down to the frame rail. But instead of hooking to the small factory return line, hooking it to the stock feed line and turning the fuel filter around. This is just one idea i have heard from some freinds. Any input would be appreciated. I have almost the same combo as Jason Cramer short of a few bolt ons but those are in the works.
Jeremy Walters
Jeremy Walters
