This part rocks!
When I turned the key I was shocked, excellent idle quality. Took it for a ride, and it spools fantastic!
Overall, very impressed!!!!! Exceptional driving around, and eliminated my tip in stumble with 55lb Seimans that was driving me nuts! (old low imp injectors)
I did have to do a little bit of fabrication!
(a little cutting was needed) My car is not a "normal" car as the factory passenger header was cut, and a 4 bolt adapter was installed, as well as having a on center d-p. I cut almost 3 inches out of the pipe in total on the turbo side. 1.5 at the turbo, and 1.5 at the weld in the bend. I can now clock the pipe as needed. I have a 8in cone on the end of it.
Thanks to Mike and Bob at Full Throttle for an excellent part.
And, thanks to Marianne for taking my frantic call for the connector I had mis placed! (and not hanging up on me for not knowing what I needed)
The chip is an Extender Extreme, and is fantastic as well!
If you are thinking about getting this, just do it!
Brian Hofer
Brian Hofer
