Fuse box by left foot kickpanel
Dhos1
Self-tuning wanna-be
Can you run two spades connectors from 1 ignition source? Basically can you have two plugged into the same area?
Yes you can and it's much easier to use the Pico tap it locks, then run your fused lines from the pigtail.
Pico 0952PT General Motors Ignition Cavity Fuse Block Tap (Clear)​
Most parts stores have them as well as Amazon ebay etc.
Make sure the load(s) on the IGN1 taps aren't over 20A, 15A if using the tap.
