Can you use the Buick 3800 V-6 spider to hold the dog bones in place?
Why can't you use the FWD 3800 v-6 roller lifters and dog bones?
Was this in another post?
Walt
I think the late 3800 FWD spider has a big hump in the middle for a counter balance shaft.... at least that is what I think the hump was for.... I tried one... it wouldn't fit....
The lifters out of a 90 deg V6 or V8 are longer than the 60 deg V6 lifters... and when you drop them in.... then put the dogbones on them.... and roll the engine over.... the lifter body comes up too high... and the shoulder on the lifter body hits the dogbone... and attempts to pick the dogbone up.
The 3800 is a 90 deg V6... so it has the taller lifters... I can only assume... that these factory roller blocks have taller lifter bores and/or smaller base circle on the cam.... IMHO, it is more likely the lifter bores are taller....hence why our old 109's require the short lifter that the 60 deg V6's use....
HTH
