Have any of you gotten the little spikes or data blips when looking at your runs in DS. They usually show up most in MAF and LV8. I used to get them all the time and it seemed worse as I added boost. I also used to get weird Boost DC readings, Instead of a smooth curve at the front then a basic flat line for the rest of the run, I would get a curve in the front then it would cycle up and down for the run. It made no change in actual boost because I am not using the selenoid to control boost.
Well I have gotten all of that to go away by shielding the ribbon cable. Here is what I did. I took the cable and and flattened it out. Then carefully wrapped the cable in heavy Duty Alum foil. Then taped the cable and foil using foil backed duct tape. (shiny silver kind)
This has made all the weird readings go away and now everything looks fine. I haven't had a single spike even at 27 PSI boost. (anything above about 22 PSI boost would give them to me every time) I also think it helped eliminate my stuttering problem I was having at 5000 RPM as I am now able to pull str8 to 5400 with no sputters.
Hope this helps
Sully
Hope this helps
Sully
