Gas gauge broken...
asrnj77
Hopefully somebody can point me in the right direction. So I changed the tank and pump, checked the sending unit and hot wire set up and everything seems good. The gauge shows permanently stuck on 3/4 full. Do I have to pull the whole gauge setup and disconnect the speedo gauge to check wiring? Should I just buy a pod mounted 0-90ohm gauge instead? Thanks,
Just a suggestion: before you go out and spend the money, put a voltmeter on the plugs of the gas gauge in the dash. That is to say, the male "rods" that the gauge plugs into. Mine periodically falls all the way to the right, and I have to rough up the rods (with sandpaper) and squeeze the plugs (for a better fit). You should read that last sentence ignoring the parentheses. ;)
