BlackMetal
- Sep 29, 2005
Sounds like I'll be going with Hydratech! lol.
SignUp Now!Have fun actually enjoyed the install 1st time ever doing a brake system like that. It will stop you and you don't have to worry about having a glove box full of 30 amp fuses. Oh yeah used a Zipsaw to enlarge hole in firewall you have to enlarge it about a 1/4" well I ended up with the larger unit. Just take your time and not try to take too much metal off at a time or you will bind the tungsten carbide bit and go thru a few like I did. Zip smooth slowly and don't Zag or the cutter will snap.
We have been using a 2 bolt mounting plate, that is retained by a 2 3/8" square nut. You would reuse the original Powermaster angle plate, but it needs a little opening for the square nut. A little opening with a die grinder/rotary burr is all that's needed. Everything else is a bolt on.
That looks great! It would look out of place in my engine compartment though......it's clean but relatively bling free!
I hope the reservoirs and filters come in soon.....I'm waiting on 'em as well!
Don't want to tease you fellas too much, but here is a pic of my new chrome and polished aluminum master Hydroboost from Power Brake Service. I have a polished reservoir and an aluminum filter coming yet, but you can admire what I did get so far. Won't be doing the install till a little later in the month, but I think it will look great. The polishing and detail are near perfect.
Did the those braided lines come unterminated ?
Yes. Exactly as you see them. I believe Bob had mentioned in an earlier thread that they come that way.
