SignUp Now!Groumet is the 1st cluprit. Lots of guys have issues with them. Easy fix though!Thanks Steve , I pulled my cable out and it looks like the Grommet is the actual suspect. Its hard to judge from pictures I took but once I took it out and had it in hand it was not cracked. I think it just needs a clean up and re torque with a new grommet.
Is the Turbo Buick TV cable that Gbodyparts has for sale a quality piece too use? my stock has a crack in the base and is leaking trans fluid, I tried to JB weld it but it still leaks.
any links to OEM?nothing like oem , heard good and bad things on aftermarket ones
One of my customers roasted a trans because the Highway Stars cable was too long. He did not check it when he installed. Luckily he left it on the unit and I caught it. The cable was sent back and they confirmed it was incorrect.HI WAY STARS HAS THE BEST REPRODUCTION TV CABLE ON THE MARKET. THE GBODY CABLE HAS A CHEAP MADE PLASTIC FITTING THAT MOUNT TO THE THROTTLE BODY- THAT WILL BREAK EASILY.
So far no issuesWhen I get the Gbody Cable I'll put them side by side and make sure they are the same length, as for the plastic clip to the throttle linkage any ideas if that is strong enough Steve?
