turb0buick57
- Oct 10, 2009
I am trying to help a friend out with this issue. I'm sure he will post at some point.
The issue is he has wot spark adv set for 21 degrees from 2k-5k rpms. However the car will not hold that spark adv and quickly climbs to 25-27 degrees at wot.
He has a gen 2 and pnp harness with wideband installed on a mostly stock gn with razors alky. His chip is an extender from fullthrottle.
volt out 1 and v2 are both set to spark control. Setting volt 1 to spark control and volt 2 to setpoint did not reduce timing any.
Anyone have a solution or some insite on why the timing won't stay down at 21 degrees?
