I have the Innovate MTX-L and it isn't listed in the GEN2. What do I use? Also the wire in the GEN2 harness it connects to is soldered to the plug-n-play harness. Do I just cut it, splice tap it,or what?
Your GEN2 is likely reading O2 sensor millivolts as configured now, so you should be able to cut the wire from the harness and connect the wideband to the GEN2. Check your sensor monitor to be sure. I think some of the plug and paly harnesses came prewired with pigtails for wideband hookup and some did not.
