Guys the car is running with the factory balancer, crank sensor and msd distributor. However with the timing locked to 15 degrees on the dfi screen i am reading 37 degrees on the balancer. The crank offset is set to 10 degree's. What is going on here?
the crank signal is set to OC lt1 hall effect, and signal rising
the cam is set to inductive pickup edge trigger rising
the ouput signal is set to points and signal falling
I am thinking i have one of these settings wrong or is my balancer ring that far out of sync??????????????
