Gen 7+ log
norbs
Classic fast, XFI, SPortsman & MS3 programming
GUys i just want you to take a look at this, and see if you see anything abnormal. The a/f looks pretty stable on the top , i would say the gen7 is doing a great job of maintaining the target a/f even with 15% correction still!
The air temp doesn't rise and do you have a 2-step? Why does the RPM drop before you launch? Whats wrong with the trans?
i launch using msbc-1 boost set low when in 1st gear, i have the step disabled. The air temp doesnt rise since i am using alky injection. THe trans slips becuase there are no professional builders in Toronto, who insist on using stock clutches.
