Finally have the GN running. I seem to have a problem with the wide band. Set up is as follows. Type 2 sensor, 02 correction on and uego selected. The correction will go -25 and will not change no matter what you do to the VE table. I can select type 1 or 2 sensor and no change. If i change the setting to HEGO it seems to work fine but wont correct below 14.0. I think I have the wrong sensor. The o2 I have is a 5 wire with 7 wire plug. The help key says that a type 2 GEN7+ sensor is a 7 wire for boosted apps. A buddy tells me the 5 wire should work fine. The cal. block is 4 wires in and 7 wires out. Do I have the wrong sensor or could there be another problem? Any ideas?
