GenII and LC-1 Install Questions...
Lobsterbak
need more money
Hey guys,
I'm trying to hook up my LC-1 to my GenII, and I need some help...
In the diagram, it says to hook the sensor ground to the GEN2, which should be a green wire. But I have the 6 wire harness, not the 7...so there is no green wire. The only random wire I have left over is a braided ground wire, which I hooked up to all the other grounds. Is this the one I'm looking for?
Also, I have the gauge for the LC-1, and the install manual for that says to use the Analog Output-2. But the GenII calls for that output. Do I splice them together, or just hook the gauge up to Output-1?
Thanks, hopefully I wasn't too confusing!
connect the purple Gen2 wire to the spot where your LC1 grounds are.
connect the orange Gen2 wire and your gauge to analog out 2.
