Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
In the quest to help eliminate wear and tear on the cam sensor gear, timing components and thrust surface of the block, I made a hybrid oil pump system for my car. It’s a cross between a front wheel drive timing cover and a rear wheel drive timing cover. The gerotor type of pump like the ones used in the front wheel drive VIN3 engines drive off the crankshaft snout instead of the timing chain, cam and cam sensor gears. This alone relieves the high stress that is put on the timing chain or any of the related components when driving an external stock type pump.
This has been working flawlessly after I got all the "bugs" worked out of it. It took me 3 attempts to get it working perfect. Looking under the hood keen eyes will recognize it's not the typical rear wheel drive oil pump assembly.
Read more about it here...Turbo Buick V6 Gerotor Oil Pump
