getting really scared with my transmission
Cleaner13
The Cleaner
sometimes when I put my car into gear I can sometimes hear a metal noise but thats not even the big issue
when I was driving tonight it felt like the car was stuttering and not moving smoothly
when the 2nd gear came around it would switch and you know how the RPMS drop and you can feel the shift?
well it felt like it shift twice
I felt it the first time and a second or two later I felt it again
anyone know what this could be?
do trannys go this fast it only has 60K miles?
any info will help
thanks
Carl
one other thing
I was driving and hit it at WOT and the boost wouldnt build as fast as it usually does
then when the next gear hit I was instantly at 5psi without starting at 0
any ideas?
thanks
Carl
Hmmm.
Stuttering & not moving smoothly, feels like it shifts twice, won't build boost as fast...
Sounds as if the TCC is locking up prematurely due to a bad solenoid. Very common problem.
how much does something like that cost?
and what can I do to check to make sure its the solenoid?
thanks
Carl
65$ from kirban,or about 45 bills at my local trans shop,save old one and match it with ne many to chose from:D
Geerrhead thank you very much
but I found out it was my dumbass who made the problem
I had by accident left the TCC switch turned on
thanks anyways
Carl
