Shakedown last nite.. Only had three passes.
At 17-18 PSI it ran 11.83 at 113.03
Then the next pass I screwed up and shut it down, left in second vs first..
Then I upped the boost to 21-22 PSI it ran
1.649
4.770
7.370
94.72
9.614
11.491
117.20
O2's were 780 as lowest, 0 KR, 1575 EGT, 18 degree chip.. really clean pass.
Need a clean pass at 25-26 PSI it should break into the 10's.. a little better weather than the 90 degree's, a little more timing.. tweaking.. should do it.
1.649
4.770
7.370
94.72
9.614
11.491
117.20
