BARRACUDA1968
- May 4, 2011
No converter will stall if the wastegate is open. PEROID. You have boost problems. You have powerlogger problems. Fix all the issue we spoke about when you called me multiple times yesterday when you were at the track. There are many things you need to address. You will never get a good pass until you fix everything. I know you are frustrated but from what you told me the car was not ready to be raced yet.
I get what you're saying Dave but the car was as ready as it was ever going to get on the street. If you've read any of my prior threads I tested everything I could and completed several logs before going. I drove 2 hours one way to tune with Bo. Made several logs around home, checked fuel pressure etc etc etc. I had some fueling issues and a minor KR issue that I found and fixed. There is NO way I would have ever found this boost issue on the street with street tires. The car had to be loaded and launched. Ain't happening on the street.
The PL issue never happened on the street so how could I fix what I didn't know was broke? It shut's itself off when I launch, at least 5 out of 6 times it did. Why? I don't know but I'll work on it. I can't launch that hard on the street.
The only reason I mentioned re stalling your convertor is because you mentioned it in a conversation we had last winter. The only way to know (per our conversation) was to go to the track. I like the convertor and you're right I need to fix my issues before I judge the convertor.
I called you once from the track at 12.44 pm after making a few passes to get some advice mainly because I couldn't get much data from the PL. Don't recall giving the impression that the car wasn't ready? At the end of that conversation you told me to call you back and keep you updated which I did at 4:23 pm when I was done. That's it, 2 call's
Now that I have the info from the track and look back at how the car did with the issues it has I have a different out look. The car averaged 17/18 psi on the best pass and managed a 7.5 ET at almost 92 MPH with a 1.8 60. When you think about that at 3940# that ain't too shabby.
daves 2600rpm 9.5 lockup has been 9's with a 45a and you have a 3250.time to turn the boost up. 16psi in 1st is not going to get the short times your looking for or stall the converter
I don't ever log from a dig on the street and almost never from a slow roll. I was told to go 60 mph in drive and roll in to it. I was getting 19 ish psi consistently. After a pass or 2 at the track with no PL data I decided to keep trying the PL but keep my eye on the gauges. I knew I didn't have any KR so I focused on building boost at the line and watching boost down the track. I was surprised to see 15/16 psi though 1st and 2nd. 3rd would net a 2/3 psi increase which matches what it did on the street in a 3rd gear pull at 19 psi. Now I know I have a boost issue. Turned the rod in 6 full turns 2 turns at a time and saw results on the last pass from a 7.7 to a 7.5. 60 was a little better and so was ET. The 6 turns didn't increase max boost just bumped up boost in 1st and 2nd. I found that interesting and told me I'm bleeding off boost some how. Evidently not enough pressure on the waste gate.
I was happy to get the data I got at the track. I'll take all the advice I've gotten in this thread and re-group before my next outing in October.
