- Jan 21, 2007
The video is as described, but I made the video for installing a bracket in the glove box for adding additional aftermarket parts. But if you need to remove the lock for any reason this is for you..... enjoy....
SignUp Now!X Ray said:The video is as described, but I made the video for installing a bracket in the glove box for adding additional aftermarket parts. But if you need to remove the lock for any reason this is for you..... enjoy....
YouTube Video
What if u have no tumblers in your lock like me!!! What can I do. I just falls out.
I was told the codes are for ALL the keys that came with the vehicle. Is this true?
On mine, the locks are different. So, 1 code would not work.
Are you saying there is more than 1 code on the g/box lock?
AIRC, the door and ign are the same.
"You can get the one with no key out, just gotta get a toothpick and push the pins down as you pull the cylinder out."
I guess I'm a Putz, as I've tried for an hr to do this......Nada, zip.
I guess it's off to the locksmith.
