Gm Timing Chain Set
PaulRV6
I want to go with a new timing chain set. If I order a replacement gearset from GM will it be a steel cam gear or the original nylon tooth gear?
What are the P/N'S for the set if they are not the nylon, otherwise it will be down to the local parts store. Thanks
paul
I don't even know if you can still get them and if you could it would definately be in the $100.00 range. Go down to the local parts store and get a steel gear setup for $20.00 and enjoy.
