GN-1 Aluminum Heads pedastal or shaft RR?
greeneyegi
Ive got scorpion singles and t/a shaft Roller rockers. Which would you use and why.
It was my understanding that two different styles of GN1 Heads exist, the 8 bolt version was shaft style and the 14 bolt was the independent style. I'm not 100% on every version available, others may be able to confirm. The shaft style rockers, if your heads support them, need to be GN1 head spacing specific also.
Hope this helps...
I can use either on these heads. I also have both types of rr. Just wondering which to go with if you have a choice.
Ive got scorpion pedestal or ta shaft mounted to choose from.
Shaft rocker is going to be a better choice.
