I have 103 plugs in now & I am wondering if a gasketed plug is better to have in the heads, better seal? I've seen other posts talking about a 4133 plug, but that is 12mm & it is a newer head & that the 12mm was help with head cracking problems. I see above that AR3935 has a longer reach, but non-projected & non-resistor. Is there a resistor & gasketed plug for me to use? I have plans to run 93 or E85 w flex sensor. I also, have IGN-1As. Or should I just stay w ungasketed, if we are worried about head cracking? I know my heads are not the 1st gen heads, because I had bought newer ones, that were supposed to be more crack resistant, but which gen, I don't know. It does have more metal along the bottom edge of the head, when bolted on the motor.
