GN Parts for sale, machined, new, used entire motor.
yarbeau
Darth Vader
I have a ton of parts for sale. All are off an 87 GN. Everything was in good working order on the car.
Pics are located Here >>>http://imageshack.us/g/1/9849837/ and more here>> http://imageshack.us/g/1/9849849/
A few pics attached at the bottom of this posting as well...
Please go have a look and email with any questions, or if you require more pictures :)
1- Under car intercooler shroud -$20.00
2- Stock valve covers great shape - $60.00
3- stock good condition oil cooler lines - $50.00
4- fuel rail with fuel pressure gauge and regulator - $90.00
5- water pump- $40.00
6- belt tensioner- $50.00
7- throttle body- $100.00
8- stock Starter- $50.00
9- misc vacuum lines and canisters? $??
10- Front time chain cover assembly- $65.00
11- Alternator - $90.00
12- Harrison AC unit - $190.00
13- fuel lines- $??
14- stock intake manifold with RJC power plate - $260.00
15- motor mounts - $??
16- flywheel - $? no idea
17- timing chain and gear - $??
18- tomco 32lb injectors (green label) $50.00
19- T&D roller rockers 1.65 ratio - $450.00
20- flat tappet lifters and pushrods - $??
21- aftermarket pistons freshly machined with zero run time, bored .030 over. (work done to pistons: hone pin bore on pistons and rods, resized rods and installed pistons on rods.) only selling with block and crank as they are machined to go together
22- coil pack - $30.00
23- Maf translator with (i believe) LS1 maf and wiring adapter. - $ 265.00
24- stock oil pan - $offers
25- harmonic balancer - $140.00
26- chrome turbo heat shield and bracket - $160.00
27- Black powder coated buick turbo 6 valve covers with silver lettering - $250.00
28- black powder coated plenum with silver top stripe accents - $??
29- black powder coated pulley rack (for lack of better term) -$??
30- Stock overhauled heads with zero run time. (replaced valve guides, hones guides, 0.0025 over, valve job, checked springs and reassembled, face was ground true) -$? offers
31- Stock machined crank zero run time (mag, grind and polish crank) -$goes with block and pistons only
32- Cam sensor - $ 70.00
33- injector wiring harness - $40.00
34- Coolant tubing - $45.00
35- K&N rocker breathers - $35.00
36- K&N cold air intake with piping and stock AC delco NON REMANUFACTURED MAF -$ 260.00
37- coolant resevoir -$25.00
38- Up Pipe with alky control nozzle - $65.00
39- Block Bored .030 over. zero runtime since machining (Mag, deck, check block, Resurface block, hone cylinders) $ includes pistons, crank, block all ready to go $2k
Please send me offers if you guys wouldnt mind. Machine work alone cost me 1600 + dollars... All work done at Moretto Motorsportz (campbell automotive) in Edmonton, AB. Have photos of everything. if you're interested email yarbeau@gmail.com or PM
Derek
  • maf:translator.JPG
All PM's and emails replied too. Pictures of parts are being uploaded as I post this. Thanks for the interest.
Apparently I can't upload more than 10 files per posting. Soooo, pictures are uploading to imageshack and will be posted shortly. My apologies
