To my amazement, I checked a couple of cylinder's valve spring installed height tonight and found them to be around 1.80 ish range. I was expecting 1.90ish range. If this is correct, it seems that I have plenty of valve spring ~ 260 lbs seat pressure.
Labor Day weekend, the car wouldn't climb RPMs at all.. took forever, almost down the entire 1/4 in 2nd gear. I decided to check my valve lash since I drive the car on the street. I found aweful valve lash adjustments, between .024 and .030+. At this time I was able to make as much boost as I wanted to but not any more power. Going from 22psi to 25psi didn't make much difference in 1/4 mile times or RPMs.
Resetting the valve train to .020 gave me power and rpm back. The cam card says .020, but doesn't say hot or cold. I did warm the car up to 160 deg idle but didn't see a difference in lash. Now the car will RPM just fine, but I can't get more that 22psi out of it.
I've checked the wastegate and it seems fine. Any ideas?
Do you think I should have driven the car and put more heat into the motor and "then" checked the hot lash? I wonder if the heat into the valves would then make them grow and I've just set my lash too tight?
I'm trying to get the car to the track this Sunday to get a 9.x pass out of it.
Thanks,
John Nguyen
Thanks,
John Nguyen
