GNS Performance now offers C5-C6 Front Brake conversion kit's
scot w.
GNSperformance.com
C5/C6 conversion kit includes laser cut conversion brackets, light weight USA made aluminum hubs and premium bearings. Includes everything needed to adapt the C5/C6 abutment brackets, calipers and rotors to the G-Body spindles. The hub features 5 x 4-1/2 and 5 x 4-3/4 bolt patterns and is intended to face mount the C5/C6 brake rotor in exact factory location (front track width is unaffected). The kit includes premium bearing cups and cones along with the correct raw hide seal for great performance and reliability. The kit has been thoroughly tested to withstand road race and auto-x competition. 100% manufactured in USA as well as tested and raced out of Phillipsburg, PA.
Kit includes: Conversion brackets, driver and passenger side aluminum hubs, correct bearings and seals to mount the C5/C6 calipers and abutment brackets. Wheel studs are not included, 1/2-20 threaded studs will be required to complete installation. Determine stud length after choosing wheel and considering offset, whether spacers are required, and after determining wheel flange thickness. Kit requires C5 or C6 calipers, rotors, brake pads and brake lines. A detailed list of GM part numbers is included.
Requirements: C5 brakes require a minimum of a 17” wheel for clearance while C6 requires an 18” wheel. Please research wheel fitment before purchasing.
Link to our website for ordering --- https://www.gnsperformance.com/brakes-g-body
Can you tell me if any issues with calipers hitting frame or crushing hose at full lock?
