turbognx75
- May 19, 2010
GNX cluster all there all works it has VDO and auto meter gauges it comes with the oil sending unit and has the water temp sending unit, has a boost line for gauge I'm including an extra cluster face plate cause the one has a crack in the plastic, it has some scratches on the bottom but when cluster face is on u can't see those scratches or cover them with black paint, included with cluster is a speedo cable.....to make this speedo work I have a number for a guy that makes speedo cables what U will need and it costs $40, its the top half of the cable made to screw on the back of the VDO speedo gauge this $40 cable connects to the bottom cable that goes to Trans....BUT there is no VSS with this setup to have a Vehicle speed sensor it will cost another $150.....BUT I could be wrong when I write this...vss controls torque converter lockup so if u have a non lockup Trans u don't need the vss, if I'm wrong on this someone chime in thanks....$750 shipped
Also a Garrett air research stretched stock location intercooler comes with brackets to mount comes with up pipe either drilled for alky or a non drilled up pipe it comes with rubber couplers and hose clamps great condition just don't have the shroud for this intercooler...$350 shipped
Ill post pics soon as my phone will let me
Parting out a tb will post more parts soon as some parts disappear
