GNX fender vent install? templates?
GS70350
Round Headlights.Like em?
Hey guys. I bought a pair of GNX fender vents at the nats this year, they are reproductions and are molded in a gray plastic. have any of you installed them and taken install pictures? i would like to know where to cut the fenders. Do you know of any template that i can use? if you have one, could you scan it for me? i dont want to mess this job up. thanks.
I did a search on GNTTYPE.ORG, and i couldnt come up with anything. Let me know if you find anything out. thanks
Are they the flexibly fiberglass one's or are they very stiff and don't bend. I have the template for the stiff ones, I don't know if it will work on the ones that are fiberglass ones.
they are flexible fiberglass ones. Kirbins sells them. im sure that they will fit the same template as the hard ones. i can check that if i see the template. i just need something to go on when im cutting. thanks
cut hole 3/4" from the fender body line, 2" from the rear fender edge measured from the upper rear corner of the vent...
Just looked at my install instructions.
