TIMINATOR
- Jan 26, 2020
Chad's brace is the only one I will ever use or recommend! It's 11ga. instead of the 14 ga of others, it may weigh a bit more, but the weight is right over the wheels, and trust me, Chad's unit is not gonna flex! A first class part from a straight up guy!
Any brace is better than none, but why not go for the ultimate right from the start? It has more mounting points(whether riveted or bolted in the 13 pre drilled holes, and plenty of area if you wish to use panel adhesive too) than the X braces, and it is thicker than the other GNXtype braces.
After rippling the "C" pillars on my other G bodies and Nova, I didn't want to munch up my Turbo T Ltd, it's too nice, but I'm not gonna climb over a roll bar since there are no dragstrips anymore around here.
Chad's unit, GNX 5th position mount rubbers, and some additional rear frame bracing should make me happy, and that's not easy! I'll report back in a few weeks when it's running!
Hey Chad, smooth deal and quick shipping! Thanks!
TIMINATOR
TIMINATOR
