GNX spec wheels
87gn joe
Hey guys and gals I need alittle help here I have a stock GN and would like to know if a set of gnx wheels with there specs would fit the car right without rubbing or sticking out to far. Or do I stick to the regular fronts with zero offsets thanks for any help 87gn joe.
Just order a set of custom made ones from Brian at gbodyparts.com You can order the backspace to your specs and they also make a 16x10
Correct off set is -15 in front & -23 for the rears.
Pete you don't like your GNX off sets we did for you?
0 off sets or all 4 fronts from a GTA will work as well.
