GNX Style Cluster
Junior Samples
Walk Away
OK Ive been reading alot on here about everyone wishing they had one So Ive done a little research.
Ive found that i can build a vacuum press for about 200 bucks, what if someone made two molds, one for the cluster case and other for the cluster overlay,
make molds out of wood?,
does the gnx style cluster fit into the standard buick case? and if so would it be easier to try and utilize the existing case for custom cluster face or make completly new case? make the cluster face as a DIY and cut the holes yourself as you add guages.
Only really need 4 working lights--check engine (red), both turn signals(green) and bright(blue) and im not real concerned with wiring, can get aftermarket speedo to plug into vss
Once you see some of the Utube videos of this dingdong making starwars stormtrooper armor, you say man dash is easy, just need a working mold and some heads to help with design
Anyone have any thoughts?
I know i want one ...see links below
www.TK560.com: Vacuform Table IV
YouTube - Broadcast Yourself.
