so i go to leave work today and when i start the car the starter sounds funny.. im like WTF?? so i pull it up on the curb halfway and turn it off... i figure the starter is loose for some reason.
WELL... i get under there and ONE BOLT IS COMPLETELY MISSING and the other one is REALLY loose.. i can push the starter up and there is like an inch of play.. holy ****!
so i was like alright.. ill just tighten the one bolt and hope i make it home.. i work 30 mins from my house and i have like 3 wrenches in the car for changing propane jets and removing the tank to get it filled.. i figure if i can tighten it and make it home ill be okay... as long as im near real tools i can do this in 30 mins
i tighten it and try to start it.. and it sounds like its binding.. so i take off the inspection cover to see.... THE MOTHER F'IN NOSE CONE IS LYING IN THE BOTTOM OF THE COVER..
thats two in 1 year that have cracked / fallen off completely.. and i always shim the starter so i know its not my fault.. crappy autozone starter BS.
so i think okay whatever ill just take it off.. I go to loosen it a little so i can get to the battery cable to take it off and *CRACK* the long bolt breaks off in the freakin block, the starter falls onto the tranny cooler lines and slides forward into the f'in frame rail and SPAAASRRRKKRKRKYM%$OYM#$!!!!!!!!!!
my car is 100% dead.. no power at all now.
and its dark outside. my friend finally gets there and we tow my car home.
wtf.... this crap always happens to me. alternators just give up on me, this is like the 5th starter in 3 years, same with batteries (it had two duralast golds on it.. and i think 3 autozone specials), 2 mafs and 3 coil packs/ modules, 2 stock turbos, and one brand new turbo...
my car is CURSED!!!
so anyone know what that spark blew? hopefully the fusible links or something right?
my car is CURSED!!!
