Daniel Jost
Squirtin six
Well after a long time of debating i have decided that i want to take the little known path and use MSII V3.0 with MSII Extra 2.1 they do have support for our DIS ignition systems and i have been talking with Matt from diyautotune about the wiring. I see that one other person has done this before and i would like to do it myself and hopefully be able to document everything that i needed to make it happen on a GN to start a small data base of swaping a Buick. I intend to start on the project in early January 2011, it will probably be a slower process with a huge learning curve, but im wiling to give it what i got. If anyone has info on doing the swap it would be appreciated, i have done quite a bit of research so far but i am very open if someone on the board has already done this and can give me a bit of insight.
Thanks, Dan
Thanks, Dan
