matt921
- May 26, 2014
So I recently pulled my engine to rebuild the bottom end and do some porting as I started to get a knock figured it would be a perfect time. So I drove it into my back yard and pulled the engine. Yes it ran. I took the engine to my shop rebuilt it fresh spun crank new bearing so on. Got it all back together cleaned up, and stabbed the cam sensor the was I seen on vortexbuick dimple to the passenger fender at 25 atdc.
So i got it home and dropped it in. plugged in all my sensors grounds exhaust basic stuff I've done before. Topper her off with fluids and some zinc additive to be on the safe side. Cranked her over and no start. Had 45psi fuel pressure so I know I have fuel. I heard some injector clicking but no spark. So I thought maybe I stabbed the cas wrong triple checked even hooked the meter up and did the gnttype instructions tuned it clockwise then counter. tried again still no spark. I could smell fuel so i'm thinking i have injector pulse. checked fuses for emc coil/spark think its ccci .Just to be safe I took the module to two auto part store both tested fine. Hooked it back up nothing.checked for voltage at the pig tail had power on the two that were battery and a few others that had lower voltage. I just can't understand how I drove it in my back yard took it apart put it back together and now nothing. :-(. maybe someone can help me out
