Well after popping a head gasket 2 weeks ago at the Southern Buick shoot out I pulled the heads and was gonna clean everything up and re-install. I had a gut feeling that I should pull the engine just to take a peak at all my bearings and make sure it looked good.
Well I pulled it out and took it down yesterday and started my inspection....got all the rods out and the bearings looked pretty good, still had most of the white coating on them. I did see some lines in the bearing indicating a lil trash but you could not feel it. I then pulled the mains and all were good except the Thrust bearing. Something big and fairly heavy went through it, it had a real deep scratch in the center. After pulling the cam all those bearings looked good except the 3 hole back, it looked horrible as if a cat with razor claws went to town on it.
I dont know what went through and why only one main bearing and one came bearing got hurt?
The oil pan was full of crap and the pickup was also full from all the material from the head gasket. I cant imagine the head gasket material being hard enough to damage the bearin? (was using the Felpro's 9441pt)
Here are a few pics's, it is hard to tell how bad the scratch in the bearing is but trust me it is deep enough to get your finger nail in.
