Pulled the front clip, and heads off the car today. I found what was causing my lifter tick. Lifter, nope. Bent pushrod.
 It was bent so that everytime the valve opened the pushrod hit the hole that goes through the head and made a noise. It was on the number 3 intake. valve opens fine, lifter is fine, cam lobe is 100%. Just a bent pushrod.
#1 cylinder intake lobe is not flat, but im 100% sure that its wore down. Lifter looked poor, had quite a bit of damage too it.
Other findings, the intake ports on the stock 80 intake are pitiful. Smaller than the head intake ports by quite a bit. The upper parts of the cylinders also have a 1/16" layer of carbon around the lip. Probably all that 3 gallons of oil I pumped through the motor before I changed turbos. The crosshatch pattern is still in the cylinders, just has a layer of carbon around the upper portion of the cylinder where the piston doesnt reach. Any good way to remove that without scrating the cylinders? Pistons are nice, didnt detonate them any yet.
 Just have a thin coating of carbon.
Tomorrow im getting my aluminum core support welded up in a few cracked spots, cleaning my front frame rails and painting them, and routing some steel transcooler lines. Was just running fuel line for temporary use, but as I look back, they have been on for a year and a half!
 Temporary turns permanent!
Just trying to get everything right.
Anybody have 1 stock 80 pushrod?
