TURBOPOWERED68
David
- Jan 31, 2006
SignUp Now!MikeT407a said:I found your powerlogger file from your post on 06-17-11 where it went 11.74 @ 114 and just wanted to say nice run.
What wideband?
BLM went to the roof.![]()
The wideband looked like it bottomed out.
BLM is showing fuel you added.
Range can differ from one wbo2 to another.
With that low boost and timing you can lean it way out. I would shoot for 11.0 to 11.5.
the alky chip at base (128) should have enough fuel for 17-19 psi
and why is the tps wot so low
you have timing in 3-4 120 which is 19 in third , with your weight and an slic thats not a wise thing to do on 93, at your boost level its ok but drop it before you turn up the boost
before you play near 17 psi set timing to 19/17
pacecarta said:i just looked
its a freakin mess
lean up to 20 psi and then it went fine around 20psi ??
idle blm 103 and cells 1 and 2 are 92/90 shows way rich
fp cranked up or .. is that chip for smaller injectors
and you check engine light is on
It's suppose to be for my combo.
I am going to send the log and the chip back for adjustments.
The light is for the boost control code 31 if I remember correctly.
i am going to put your chip back in and play with that
