To muddy the waters a little, here is another file.  Same settings on everything as in the first file, but this time I asked Brian to drop the fuel pressure, as he had it set higher than recommended (understandable due to the severe lean condition seen at idle).  We did not drive the car like this, only sat and idled it.  Well, not totally true, I had him give it a little gas for a while, but the whole last half of the file it is just idling.  The idle BLM did a flip and went screaming upwards, but as the log ends, it was somewhat still in control, the O2s are moving around still.  Maybe we needed to set it at an intermediate pressure and then go for a drive and let everything learn and see what that resulted in.
I should mention that he does have a wide band. We didn't have time to get it hooked up to my PL, so it isn't logged, but when the NB reads lean, the WB reads lean; when the NB reads rich, the WB also reads rich. At the end of file A, when the NB is showing 0.050 volts, the WB was showing a/f ratios of 17+. I didn't *see* any problems with what the O2 sensor was saying just based on watching the WB gauge. Of course, super easy to miss something without it being logged.
Eric, if you can give us a setup you'd like to see logged, I'll run over there and log it and post it, and maybe we can trial and error our way to a solution.
John
John
