Jun 24, 2007 #1 B brohr01 New Member Joined Jan 24, 2005 Messages 19 Hello, I think i threw a spring on my governor causing all of my trans issues. I was wondering if you needed to drop the valve body to replace it or can i access the governor with just removal of the pan? Thanks Bryan
Jun 24, 2007 #2 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 pan only Egg shaped aluminum cover @ rear of trans held in with 4--13mm head bolts. Remove bolts and governor will come straight down.
Jun 24, 2007 #3 H Hacksaw Member Joined Oct 4, 2005 Messages 376 Also, the spring may get caught in the filter, so if it's missing look there.
