I have not seen anywhere that showed how to put this spoiler on and I was scared to screw into the trunk and mess up sooooo. I went the SMC way and got a quart of SMC Filler/Bonding Agent and molded it to the trunk and sides. The important things are. 1. Make sure you rough up the areas with 40 or 80 Gritt 2. Do the trunk spoiler first and put some weight on it while its drying so it hardens on tight. 3. The end caps where a little low on the front spot so i had to build up the body so the spoiler wa level all the way across. 4. sand all seams so its clean lines and make sure you have all edges fill so no water gets under the spoiler.
Here are a few shots below it took a bout 3 hrs cause i was tryin for perfection. Im going to shoot highbuild and block the area so it look clean
hit me with any questions
