Greddy Boost Control
dvernst
Where have you guys mounted the solenoid for the boost controller? I mounted mine on the same bolt that holds the factory one, but I don't know if it gets too hot there. The instructions to install it somewhere where it will stay cool?
huh?
just an idea but maybe on the firewall. You know where some people put their aftermarket injector harness relays at. Maybe a cooler spot.
Works fine on valve cover , just keepwires away from intake!!
thanks JD
O.k. yeah I routed the wires arond the front of the intake. I tucked it in to a some wire loom that was already there. Thanks
