as far as getting rid of lag.you need to adjust the start boost setting(set gain)you must be carefull becuase this setting is done by actual boost numbers ,not percantage like the rest.i made that mistake myself and actually had this setting set on my car at 5 pounds of boost thinking it was 50%.for example,it reads 50 which which means 5.0 in actuality.
also keep in mind that even if you have the start boost(set gain) high with a weak spring it will still open sooner.i have found thru trial and error that my combo of a heavy spring rate and these controller settings work the best on a turbo buick with the greddy.
good luck.
nick,
