Grinding noise comeing from trans
84' TurboRegal
Only a 6 cylinder?
I was just cruiseing around 40-45, and the trans made a poping noise, and now doesnt work? Little bit of fluid drupping out, im thinking maybe the torque converter balooned? but im not sure what to look for, all i know is its hotter then hell right now... When you restart the car it sounds as if something is either grinding or scraping somewhere, if the converter balooned up could it have put a hole in the engine?
Broken shaft on the input drum.
