gtq how many types?
norbs
Classic fast, XFI, SPortsman & MS3 programming
Can some explain the difference between all the gtq series. I am looking for a gtq but i heard theres many types
john craig gtq 70
pte gtq70
gtq with billet wheel?
gtq with ported shroud housing?
Which do you pick? its just too confusing!
The gtq is just the exhaust wheel. Then you have a standard 70 mm compressor wheel. Or the gt 71 compressor wheel. Then you have the t-netics compressor cover. the pte 4"inlet 3" outlet cover in the ported shroud and the non ported shroud version. John craig also has a mid sized housing that is in between a 44 style and the big housings. It has a 4" inlet 2.5 outlet. Lonie d. had one on his car at bradenton and if i had to do it over again that is what i would go with.
