Guage lighting Issue
85RegalLimited
My dash lights used to work, then all of a sudden they stopped working. I replaced all the fuses, and nothing. So now driving at night I cant see how fast Im going. Does anybody know where I can get the wiring Diagram for the dash lights from the fuse box or something , or maybe something where I can trace the lines.....by color? Also I want to put in 2 pod gauges, one for temperature and one for tachometer. My car has neither one. I want to know where they are supposed to be connected to. Thanks in advance.
Have you checked your dimmer switch?
Most probable casue is it has gone bad or just loose.
Some thing to try, with lights off can you see your led tach and boost gauge?
When you turn the lights on do these go dark?
I have a similar problem.....
Yes & Yes - Does this mean it is the dimmer switch?
my dash cluster is only speedometer and fuel guage. But ill try that dimmer switch. Never thought about that.
